| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: super 77 governor
[Return to Forum]
| Author |
[Modern View]
| Troy Benner
11-13-2012 11:27:55
74.36.105.165
hi all,been sorting out a bunch of issues with this super 77 I recently got. have most issues worked out now but a new recent problem just showed up. After changing the oil, I moved the tractor out of the shop, everything was fine. Went back 15 minutes later to bring it back in and when i started it back up the engine revs went thru the roof with the hand throttle in like the 3 or 4th notch is all, tried to change positions and the engine speed would not come down. got it back inside and also noticed it seemed hard now to get the hand throttle to the fully closed or all the way up position, like it had resistance againist it. Couldnt see any visible linkage problems being bent or broken, so I unhooked the rod from the front governor lever to the carb and with the throttle closed at the hand control(up) the governor linkage is well past the arm coming off the carb, like a 1/4" past so basically if i hook it back up, with the throttle closed on the lever it wants to hold the butterfly in the carb well up off the idle adj screw, almost 1/2". I assmumed something in the governor is now gone wrong, so I loosened the bump screw lock nut and backed the screw almost all the way out and the governor lever never released at all! so I havent been into these before but I assume the governor has to come apart?? just for info the carb was never touched and I checked the high speed adjustment as well as idle mixture screws and they are right on factory spec so should be close enough not to be inducing a problem and also it runs fine if you take the governor out of the equation and just move the butterfly by hand. Any ideas? |
| J. Schwiebert
11-13-2012 13:31:52
209.143.33.150
Re: super 77 governor in reply to Troy Benner, 11-13-2012 11:27:55
| Take the air cleaner and then the governor housing off. Then pull the weight assembly out. I think the problem will be very aparent when you pull it out. |
| Troy Benner
11-13-2012 14:21:32
74.36.105.165
Re: super 77 governor in reply to J. Schwiebert, 11-13-2012 13:31:52
| ok I will try that thanks. where is a good source for parts if I need any? Am I correct in assuming that the arm should have returned all the way once the bump screw was backed out? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
