| Author |
[Modern View]
| Mr C
11-11-2012 06:02:46
173.78.233.218
   trying to post a few pics...hope it might help. |
| thompson mike
11-11-2012 13:25:33
75.104.175.75
Re: 1355 orchard in reply to Mr C, 11-11-2012 06:02:46
| I am no expert but in California I never saw a real orchard from fiat. There was what we called a vineyard special which yours appears to be. The dealers out here took the standard fiat tractors and would rotate the rear final drive to either lift or lower the back end then cut the front spindle to match. |
| Mr C
11-11-2012 14:23:37
173.78.233.218
Re: 1355 orchard in reply to thompson mike, 11-11-2012 13:25:33
|  i think its a rare tractor. my dad has a 1365 and my final drive is much more narrow. also in the sparex parts catalog they have parts only for a 1355 orchard. i saw a picture of a full dressed (orchard fenders) 4 wheel drive with 1365 decals. maybe it was a mistake on the decal...or another custom build ? |
| thompson mike
11-11-2012 15:18:34
75.104.175.75
Re: 1355 orchard in reply to Mr C, 11-11-2012 14:23:37
| I don't believe those are original equipment rear fenders. Out here there were several companies making those for all the brands. |
| J. Schwiebert
11-11-2012 14:46:21
209.143.33.150
| I need to think on this a little bit, but I do know for the 1255 they built a narrow tractor and it was called a vineyard tractor. |
| Mr C
11-11-2012 14:58:37
173.78.233.218
Re: 1355 orchard in reply to J. Schwiebert, 11-11-2012 14:46:21
|  thanks to the both of you guys for the help. i thought it might be an older model to...but it has a 4cly engine with the improved 4 sp transmission. i read somewhere that the front axle changed in the 1355 series to the "U" type? i have spent way to many hours on research, confrimed by my wife..lol!..but i'm on a mission to find out what this tractor is. |
| Mr C
11-11-2012 15:49:41
173.78.233.218
Re: 1355 orchard in reply to Mr C, 11-11-2012 14:58:37
|  thanks mike for the info on the fenders. this tractor is so narrow, i'd love to have those fenders on it as well. |
| Mr C
11-11-2012 17:12:04
173.78.233.218
Re: 1355 orchard in reply to Mr C, 11-11-2012 15:49:41
| i also read that there were 1,500 1355's made. if it is a 1355? so not sure how many of those would of been vineyard/orchard? if its truely rare and a collector would like to restore it and give it a great home, i'm very open to selling it, but also in keeping it as well. it does have 50mm brake bands, as i have pulled one wheel and worked on the brake. i have ordered and recieved the overhaul parts for the 3pt lift and am in that process. |
| gordey
11-11-2012 17:49:27
209.91.107.218
Re: 1355 orchard in reply to Mr C, 11-11-2012 17:12:04
| Keep in mind that Fiats aren't nearly as collectable as American built Oliver's |
| Mr C
11-12-2012 02:11:36
173.78.233.218
Re: 1355 orchard in reply to gordey, 11-11-2012 17:49:27
| thanks gordey....i'm not a collector, i grew up on a farm riding massey harris, and my dad now has several olivers and a white. i bought it to use on only a few acres, then started looking for repair parts. thats when i found it must be somewhat rare? i wanted to put a loader on it, but its so narrow, not sure about the mounting. and it doesn't have power steering. i have no idea its value, it does run fine, and i am repairing the 3pt lift now and will repair the other brake next. with the available front sheet metal put on, power steering added and painted it would be fine for myself. i have seen like models in the 5k area. any idea what its worth? |
| thompson mike
11-12-2012 03:50:36
70.197.7.211
Re: 1355 orchard in reply to Mr C, 11-12-2012 02:11:36
| I saw one at a dealer out here in Cal about the same condition it sold for 2500.00. I am pretty sure it went back to work in a vineyard. This was six months ago. |
| Mr C
11-12-2012 07:04:45
173.78.233.218
Re: 1355 orchard in reply to thompson mike, 11-12-2012 03:50:36
| just got some new info...i'm 98% certain now its a early model 1355 orchard. a 1969 or early 1970. the axle and no power steering, the seperate fuel filters and now the most conviencing the fenders confirm the orchard model. is there a way to back search a eninge number, or some other numbers off it to get a serial number? |
| Mr C
11-12-2012 07:09:33
173.78.233.218
Re: 1355 orchard in reply to Mr C, 11-12-2012 07:04:45
|  this is a diagram of the orchard fenders...which mine match. |
