Oliver 88 main Bearings
Old Bob
Crank in my Oliver 88 needs to be turned. It has a Waukesha (sp) engine. The specs for the mains were 2.625 when new. The mains need to be turned 40 thousandts. I have not been able to find any main bearings like this. Does any one know where I can get my hands on some of these??
Is this a gas or diesel 88? I don't think F-M or Clevite has produced 40 under bearings for at least 20 years. I just checked my 1991 Clevite bearing and they were not listed anymore. If you do find some remember you can run gas bearings on a diesel crank but not in a diesel engine.
Pauls in Mo. can rebabbit your old brg. shells. Then align bore to size they do good work. email if you need a phone number. Earl
id consider having the crankshaft ground under, n have the surfaces built back to standard. its not as expencive as you think.
