Block for Oliver Super 88
Old Bob
I need a block for a super 88. Tore ours down, ordered the parts to re-build it, then today we were cleaning the inside of the block where the o-rings go, and there was a crack in between two cylinders. There was no anti-freeze in the oil, but that crack is still there. I do not know if it was leaking or not. Any suggestions?? Where do I find one?? If you have one call me at 479-675-6115 or e-mail me at [email protected] Thanks in advance I guess as they say: Restoration is Frustration
http://www.powermaxparts.com/DEMO/WA-265-E.html
I've rebuilt a couple Super 88 engines with kits from this company that my local parts store is a supplier. Its sometimes called Tom's Agri-Diesel as well. As you scan down the listings for pistons and sleeves there is something called a "block repair sleeve." Not sure if this is what you need to fix your block, but its worth a look.
