TractorLinks.com
Show Parts for Model:
Re: differences in 453T piston/liner kits
ollie gm
10-30-2012 12:10:14
There are actually several differences in 4-53 x-head pistons, probably the 2 that you are looking at are pin diameters and port heights. The more expensive kit probably includes new bushings and pin caps for the larger diameter.
I usually use the .002" oversize liner on engines with high hours. You really need to know whether you have a former, current or silver style 4-53T. Your engine serial number will tell you this. The model number will look like this XXXX-X3XX. The 3 means turbo charged. Most good parts houses will give you the exact replacement with these numbers.
Also remember that you need to match your piston crown shape with the correct injector nozzle configuration. I have worked on several engines where the owners have tossed in huge 92 series injectors. All they have done is make lots of black smoke and totally whacked their hp and torque curve.
J. Schwiebert
10-30-2012 13:15:30
 Re: differences in 453T piston/liner kits in reply to ollie gm, 10-30-2012 12:10:14
He is talking 53 series, not 71 series. The liners come in stanadrd and 10 over, not 2 over. I agree make sure the block has not pitted and the top half is in alignment with the bottom half, if not it will need to be fit for the 10 over liners
ollie gm
10-30-2012 14:42:47
 Re: differences in 453T piston/liner kits in reply to J. Schwiebert, 10-30-2012 13:15:30
Over time, the dry section of the 53 series liner/block can wear so DD makes a .002" over to compensate for wear without boring. These liners will be marked "STD No. 2". And when you get into the oversizes that actually require boring, the more common are 10 and 20 over.
