Anonymous-0
Hi guys,
I just put in a clutch on a 1968 770 Oliver with no power booster. It didn't come with directions to adjust the pressure plate. My problem is that the length of adjustment is all the way out and the throw out bearing is barley moving the fingers on the pressure plate. Did I put something together wrong? What could cause this to be so far off? I appreciate any and all help.
As a quick test look and see if the rear of the fingers is about eavan with the front edge of the preasure plate cover.This is about were they should be, not as acurate as measureing but close.Its possible to other parts worn or wrong.
