projects for the winter?
Oliver Heritage did a thing on their facebook page a while back where they had "show us whats in your shop now" thought it would be neat to see what everyone else is up to in the "off" months. Here is a pic of my '47 Oliver 99 that I'm restoring.
I don't have a picture right now,but the Super 55 is in there waiting for the body work.
The pilot bearing seized up in the 1600 Monday and the rod for the tilt steering is broke,so that needs to go in as soon as I get time.
Well, neither of mine are full blood Oliver. I have G955 Minneapolis Moline that needs a new flywheel ring gear, a starter and a radiator. Then I have a 2-70 White that is getting a 6BT cummins and going on a diet for the upcoming pulling season. Those are both just toys for when the budget allows. The only real project will be looking for an unknown noise in the rear end of my 766 IH, which is used daily for feeding.
Casey in SD
Casey..where in SD are you located? Im in SW Minnesota. Wouldnt mind looking at your G955 sometime.
I still gotta pull the cover off the rear of my 1600 and get the 3 pt. linkage hooked up again. Been so busy all summer with al the other jobs as they needed to get done so I haven't had time to look into it. Been using it without a seat since I got the pump back in it, but all we've used it on has been the blower for straw and corn. She hasn't seen much use at all this year...
My most pressing project is getting my snow blower running again. Was stored under a leak in the roof all summer so the carb is all messed up. The choke is frozen and it leaks gas when I turn it on.
Donovan from Wisconsin
No pictures, hope to overhaul 1800C, fix the brakes, replace the 2 speed gearbox, replace the ring gear on a B AC, Fix the gearbox on the mower, replace the hayconditioner sickle, get dads tractor going, paint it, fix the brakes on it.
