TractorLinks.com
Show Parts for Model:
Re: 1850 perkins crank pulley revisited
mm585
10-25-2012 11:07:25
Off the subject but not really. I have a 1955 that I repowered with a 354 out of a 2-105. I used the 1850 front cover and mount as well as the tub. The problem is that I cant keep the balancer tight. twice a year the balancer comes loose. I have tryed lock tite and that didnt seem to help. I tightened it up out in the field the last time now it wobbles. whats the cure? I doubt that it makes any diffrence but the inj. pump is set at 10% over factory spec for an 1135 massey witch is 135hp out of the box. Thanks.
Broke again
10-25-2012 11:19:56
 Re: 1850 perkins crank pulley revisited in reply to mm585, 10-25-2012 11:07:25
What shape is that wedge ring in? Maybe it's the problem. My original is splined to slip over the shaft. The updated version AGCO sent me is not splined. Don't know what that matters but the Perkins dealer has the splined ring I need on the shelf, or so he says. Also, locktite is the right thing to use I am told by the Perkins dealer. No neverseez or lube, it needs to be dry and tight.
