Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: over running PTO clutch question
thompson mike
10-18-2012 22:09:17
Thanks for the input. The pto shaft has both a slip and an over running clutch. Slip clutch I was familiar with and it works as it should. Over run however is worn out where the spring loaded pins will not catch and drive the shaft. Thanks again
e
10-19-2012 07:22:09
 Re: over running PTO clutch question in reply to thompson mike, 10-18-2012 22:09:17
A few things to consider in addition to the other responses. Remember that even fairly late model Allis tractors did not have true "live" pto like your Oliver does. If you wanted to change gears, you pushed in the clutch and the transmission was still coupled to the PTO. Hence, the tractor could be pushed and it was almost impossible to change gears until the mower spun down. This is why the put in overrunning clutches.
Your Oliver is totally different. You can clutch, change gears, do whatever with the transmission and it's basically 100% decoupled from the PTO hence eliminating the need for an overrunning clutch.
In addition, even when shutting off the implement, the PTO on your 1855 includes a wet type fiber brake of a single plate design. This brake can handle a reasonable amount of slipping associated with stopping a high inertial load. We have a 720 Woods and there I've had no issue applying the brake with the mower going full tile. That said, the best method is to shut off the PTO wait for it to spin down a bit, then engage the brake.
Moral of the story, that overrunning clutch is unneeded with an Oliver and is just another liability.
