Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oliver 88 diesel ?
J. Schwiebert
10-16-2012 03:28:31
To start with retime the pump. Crank it over to F. P. Then take the 2 screws out of the pump drive and turn the pump till the pointer lines up. There are many holes in the pump drive gear. Probably 40 years ago I calculated once how many degrees the timing would change, now do not remember how many degrees that was. Remember wear in the timing gears will also retard timing. You may need to advance it one set of holes. Confused? Do take that maniold off so you will know if several cylinders are the problem or if they all do. How about sticking valves?
