TractorLinks.com
Show Parts for Model:
Re: Oliver 88 diesel ?
benelli7979
10-15-2012 18:37:27
I have not taken the manifold off . Whe you align the F.P. mark
The pointer on the pump is a little off maybe one tooth. J can you tell me a little more on flow timming. I honestly believe it is a tooth off on timming but it starts decent then surges. I just want to elimanate timming before pump overhaul.
J. Schwiebert
10-16-2012 03:28:31
 Re: Oliver 88 diesel ? in reply to benelli7979, 10-15-2012 18:37:27
To start with retime the pump. Crank it over to F. P. Then take the 2 screws out of the pump drive and turn the pump till the pointer lines up. There are many holes in the pump drive gear. Probably 40 years ago I calculated once how many degrees the timing would change, now do not remember how many degrees that was. Remember wear in the timing gears will also retard timing. You may need to advance it one set of holes. Confused? Do take that maniold off so you will know if several cylinders are the problem or if they all do. How about sticking valves?
