Mitch Poindexter
I've pulled together most of the parts and pieces to swap out the old tired Herc in my 2150 with a new military multifuel engine. I have a newly rebuilt Bosch 100 inj pump (250 flywheel HP expected) to install on the engine. I'm building an O/U with the intent of being able to carry the additional HP. Having looked at the existing single disc clutch, I don't believe it will carry the HP (talked to the Southbend clutch guys and they agree), so I'm curious about what others have done with the single disc 14" clutch to withstand the additional HP on these tractors. Is this as simple as bolting in the double disc clutch from the 2-180, or do I have more work to do?
This tractor will not be used for pulling a sled. But will likely be hooked up to something that we probably shouldn't try pulling.
