guss62
got the trator running plowed for two half days heard screecing sound for about a minit seemed to still run al right then it started blowing oil out of the front piston still seems to run all right the starter seem to be pulling hard when I start it my be losing a little oil presher any input just redone the head this is a 453 4 valve ??
How do you know it's the front cylinder thats pushing oil? My guess is that your engine had a rather high speed startup when you were having governor problems and something was starved for lube.
J.W. is right, you probably have a scuffed piston and/or spun bearing. Take your oil filter off and check for metal on the element. This should indicate which direction you need to go.
I took off exust manafold no it never had a high speed start up while we where woking on it and I took the oil filter off I looked at oil and used a magnut very little particals in it ?
What bothers me is your loss of oil pressure and hard cranking. This points to a bearing issue.
What I would do next is drop the pan and check the rod bearing insert and crank journal for overheating. Then roll the crank over to look at the bore, small end of rod and piston skirt.
I have hundreds of hours working on this model of tractor and never had the need to drop the pan in-frame, I usually just yank the motor. I actually don't know if this can be done without looking at the manual. Just guessing now, you may have to drop the axle wishbone and oil pickup tube to remove the pan.
Look over #1 bearings & bore real close for loose metal particles.
Good luck.
