Old Bob
I have a Super 88. A nice tractor. Not started in probably 4 years. Put a battery in it today and it was stuck. Oil still looks great and radiator is still full to the top. I am a JD guy, and have never attempted to loosen up an Oliver. What are my best options to remedy this??? Thanks in advance. Old Bob
Try tranny fluid and diesel fuel mix or penetrating fluid, let it sit a few then use a breaker bar on the front nut. Not a lot of pressure or you will ruin the threads in the crank. All else pull the head. This may well be the first thing you need to do.
Or put the magic elixer in the cylinders, leave the tractor in gear, and then just rock the back wheel a little, both ways, every time you walk by it. May take a couple of weeks, but it will probably free up.
yap ! I've been through this before and had good luck with penetrating oil -- let it sit for a few days and start rocking her . But I always remove the vale cover and check for stuck vales by hitting them gently with a hammer or spinning the push rods -- good luck
ps. I have the exact same tractor 1956 super 88 diesel
