oliver super 99
Why do you need to take the nuts off? do you still have the original skinny nut or has yours been upgraded with the wider nut?
One was a little loose. Still original skinny nuts. Just a habit to check the hub nuts as my 1937 28-44 has a tendency to loosen the left side bolt and this s99 was the same. Torqued it to 500ft lbs should be good
I haven't seen one loose before, but it must have happend occasionally and thats why they went to the fat lock nuts. We tightnend ours with a snipe as thats what it took to get them loose.
