white 2-70 throttle won't stay up
farmkid84
New User
On my white 2-70 the throttle nut is as tight as it goes, and the throttle won"t stay up. Any help would be appreciated.
there is a roll pin inside that nut that holds the friction cone mechanism to the throttle shaft.this often gets sloppy and allows for throttle movement,for example it will stay at 3/4 throttle but you can still push it wide open but then it falls right back.tighening that nut will not fix the problem.
