Front wheel hub guessing game
I have a front wheel hub that I don"t know what it came off of. The part number is 104326A. It looks like the common 4 digit front hub. But i can"t find what it came off of. Did Oliver use tractor hubs for impliments or running gears? I want to check this as to see if I can use this on a 1550 set back axle. I hope the bearings are the same.
thanks
   Brad is mostly correct.  It was used on the larger tractors from the 1800, 1900, 1750 through the 1955 tractors, however it was used on the 770, 1550, 1555, 1650 & 1655 High crops only.
   Part number 104 326A subsitutes to 155 192A thus that is the number you will see on the later tractor hubs.
Ok I see now. I also see that the later hub takes the same bearings. Would I not be able to use this on a set back axle? thanks
Never-mind. It didn't register as fast as it should. This hub will work for me so you say. Thats great news. Thanks for the help both of you.
