Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Hydra Power mystery
09-24-2012 05:56:26
No,I'm not coasting back down. When it wasn't right it would go in to free wheeling like you would expect in underdrive,but since it "fixed itself" it's holding in direct. Darndest thing I've ever seen is all I can say. It used to be slow and slipped in to direct slowly when it even went in at all,now it goes in with a distinct thud.
OLarry from MD
09-24-2012 15:11:31
 Re: Hydra Power mystery in reply to rrlund, 09-24-2012 05:56:26
Heres a wild guess the presure relief stuck with some stuff from the overheated oil and now it makes more preasure.Years ago i had one that wanted to shift to direct all the time as soon as i started the engine.I ended up removeing the relief spring and it still did it.Ended up finding the return plugged by thick goo on the bottem of the unit.
Mitch Poindexter
09-24-2012 06:42:29
If I send you a 3sp that is doing exactly the same thing in over, can you reproduce your results?
09-24-2012 16:37:03
 Re: Hydra Power mystery in reply to Mitch Poindexter, 09-24-2012 06:42:29
I can drain it and run up and down the silo. Seemed to work for me. I'm starting to wonder if we all need to switch from Dexron to that Mercon/Dexron combo. Mine acts just exactly like something had been plugged all those years and all of a sudden popped loose.
