77 Governor spring snapped!
Eric-IA
So I was driving down the road the the other day and all of the sudden it kicked down to idle. Did some checking and found the spring attaching the throttle rod to the governor arm broke. Luckily, I friend stopped and had some wire so I jimmy-rigged it so I could continue.
I checked on Korves website (and several others) and didnt see a listing. Are new springs avail. or would I need to find a used one?
Thanks
pic
Part number is H-282. This spring was used on all models even on the 1800 A series tractors so finding a used one should not be a problem.
Call tom at obrian county implment in sheldon. They have new springs on the shelf from agco. As I recall around $20.00. 712-324-4871
