Cockshutt 50 diesel starter
emtiv1099
I have a 50 diesel that I have put a 262 in. I do not have a starter for this tractor. I was wanting to know if there was some other tractor starter that I could use. Or if some one knows the numbers to change to a gear reduction starter. Thanks for the help.
I used a nippendenso. Like a John Deere would use. Just count the teeth on your fly wheel and a local shop should be able to find you one. I will try to look for a number off mine.
