| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: Oliver 60 electrical problem
[Return to Forum]
| Author |
[Modern View]
| Harold Crosby
09-21-2012 13:45:18
64.223.223.198
I am trying to rewire an Oliver 60 I recently bought. When I push the cut out contacts together the amps meter hand jumps as far right as it will go and stays there whether the engine is running or not. I dont' have any lights and don,t plan to. What do I have wrong? |
[Reply] [No Email] | |
| Harold Crosby
09-25-2012 16:27:19
64.223.223.198
Re: Oliver 60 electrical problem in reply to Harold Crosby, 09-21-2012 13:45:18
| Thank you all for your help, I connected a wire from the field terminal to a ground and got more than 10 amps on meter but may be meter error. I do have original type gen and cut out I guess i need a light switch with a resistor? |
| b a star
09-21-2012 23:41:08
209.50.28.66
| | You didn't give us much information so we have to make some assumptions. Does it have the original generator and cutout relay? The original system used a third brush generator. The field coil circuit went to ground through the light switch. With the light switch pushed "in" (low charge) it produced 4 amps (field circuit through the resistor on the switch to ground). Pull the switch to the first stop and output incresed to 10 amps (field circuit now bypasses the resistor and goes directly to ground). upon startup as the generator begans to produce voltage the coil in the cutout gained an electromagnetic field that closes the points completeing the circuit to the ammeter then to the battery. You manually close the points in the cutout without the engine running and it completes the circuit to the battery and you will have high amperage flow through the wires to the generator armature and field circuit (ammeter will show max. discharge). I told my students that all electrical components are built with smoke in them. Hold the points closed for very long and the smoke will start to come out! |
| 60 Fan
09-22-2012 08:18:12
208.126.138.2
Re: Oliver 60 electrical problem in reply to b a star, 09-21-2012 23:41:08
| Excellent explanation,. I have found as well rewiring is much easier using "factory cloth" wiring packages from Korves. As well as being like factory wires each are labelled with a number corresponding to instruction sheet where to where. Makes a nice neat installation. :D |
| rrlund
09-21-2012 15:56:26
207.241.137.116
| Reverse the wires on the back of the guage. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
