| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: Detroit 453 Engine
[Return to Forum]
| Author |
[Modern View]
| Ed Schulte
09-18-2012 09:18:17
67.224.22.146
How is diesel fuel from fuel tank on my 1900 tractor, with a 453 detroit, getting into crankcase. Thanks for helping with this problem. Ed |
[Reply] [No Email] | |
| Shryl
09-18-2012 20:00:25
174.252.100.4
Re: Detroit 453 Engine in reply to Ed Schulte, 09-18-2012 09:18:17
| I have a question. Can you interchange a 353D and a 453D in tractors. What tractor would be best. |
| scottf in WA
09-18-2012 12:11:33
130.76.32.212
| I"d check the fuel jumper tubes first. Make sure they are tight but not overly tight and no cracks. Then I would replace all the crush washers under the fuel towers. |
| duane o.
09-18-2012 09:39:40
68.171.231.83
| There is a few different ways for this to happen. An injector is leaking down or the fuel rail jumpers are cracked at the flared fittings and or the gear driven lift pump is leaking and the vent is plugged with dirt or the pipe plugs were never removed when it was installed. It needs to be vented with the correct pipeplug removed. Hope this will get u on the right track |
| Ed Schulte
09-19-2012 07:31:35
67.224.22.146
Re: Detroit 453 Engine in reply to duane o., 09-18-2012 09:39:40
| Duane, where can I get the correct vent plug for the lift pump on 453 detroit engine. Thanks Ed ph 5639274919 |
| duane o.
09-19-2012 21:22:42
68.149.231.9
Re: Detroit 453 Engine in reply to Ed Schulte, 09-19-2012 07:31:35
| there should be a 3-4 inch tube hanging down from the pump. if yours is not there im sure it can be made from a piece of steel brake tube and fitting. and it should be hanging as close to straight down as possible and close to the engine block.if its there make sure its not plugged. |
| Ed Schulte
09-28-2012 07:17:16
67.224.22.146
Re: Detroit 453 Engine in reply to duane o., 09-19-2012 21:22:42
| I found the problem that the Detroit 453 engine leaking diesel fuel into the crankcase, ther are 2 seals in lift pump ,I replaced them and problem is solved. Thanks for all the replys. Ed |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
