Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1755
[Return to Forum]
Ron H
09-10-2012 18:15:22
71.37.38.93
Found a real nice 1755 what should I look for? The owner says 2800 hours with a white cab. Tires are real nice with front weights. The best deal its close to home. Asking 4000. Its a diesel wide front. Thanks
[Reply]   [No Email]
Bradwi
09-10-2012 18:30:44
70.226.169.140
 Re: 1755 in reply to Ron H, 09-10-2012 18:15:22
Check the rear end fluid level,overfull may indicate a leaking pto unit.Look in the oil fill hole on the engine for 12 point rod bolts,this will indicate if it has possibly had some engine updates.the water pumps have a weep hole on the bottom side if wet indicates bad pump seals.I also request that it not be started prior to my inspection. Then usually take an 1-1/8" wrench and let the engine oil drain plug almost out of the pan until i get a drip or two to make sure there is no water in the oil.Tractors this age often have failing cylinder sleeve o rings causing coolant to get in the oil.Just my 2cents good luck!they are a nice tractor
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
