TractorLinks.com
Show Parts for Model:
1655 gear oil change
C.R.
09-03-2012 08:35:26
I decided to replace the gear lube on the oliver this weekend I have been meaning to get this job done "for a wile" and I wanted to do it on a warm day Im glad I drained it the oil that came out looked like carmel sause real ugly! filled her up with ten gallons of fresh juice and should be good to go for a wile
pine forest
09-04-2012 06:58:05
 Re: 1655 gear oil change in reply to C.R., 09-03-2012 08:35:26
I have a 1755 diesel that I need to do this to. Where is the filler plug and the level plug?
J. Schwiebert
09-05-2012 17:26:02
 Re: 1655 gear oil change in reply to pine forest, 09-04-2012 06:58:05
Your fill plug and the check plug are both in the back. Do you do any PTO work with the tractor or a grade ? The capacity is also more than on a 1655. I will need to look the capacity up as I have not filled one in at least 36 years.Your filter is on the left side like on the 1655. J.
C.R.
09-05-2012 02:49:01
on my 1655 the filler is under the floor board there is a round plug that you have to pry up and under that is the filler for the gear oil the level is on the right rear of the axel housing it takes about ten gallons to fill
J. Schwiebert
09-03-2012 09:31:59
Change the filter as well? Also I don't remember the capacity but make sure the oil level is to the check plug or a little above if it is a little hilly where you are.
C.R.
09-04-2012 02:31:47
 Re: 1655 gear oil change in reply to J. Schwiebert, 09-03-2012 09:31:59
is that the filter on the left side kind of up under the platform ? I need to do that again
OLarry from MD
09-04-2012 09:38:13
 Re: 1655 gear oil change in reply to C.R., 09-04-2012 02:31:47
Yes if the oil looks bad the filter is too.
