Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: oliver 77
[Return to Forum]
pulling kid
09-03-2012 06:47:24
174.124.67.139
i have an oliver 77 that will miss and sometimes backfire, when it runs smooth it runs really good. it will usually run 4 or 5 minutes before it will start to miss again, eventually shutting itself off, it will start right back up, sometimes running good, sometimes not... it has a 12 volt battery and 12 volt alternator. does it need to be reduced to 6?
[Reply]   [No Email]
mkirsch
09-04-2012 07:11:05
64.80.110.74
 Re: oliver 77 in reply to pulling kid, 09-03-2012 06:47:24
The coil has two terminals marked + and -.
On a 6V positive ground system, the - side is connected to the power coming from the ignition switch. The + terminal connects to the distributor.
To "change polarity" all you do is swap which wire is connected to the + and - terminals on the coil. The - terminal now connects to the distributor, and the + wire goes back to the ignition switch.
Do you have a ballast resistor installed in the wire between the ignition switch and the coil?
If not, you are burning up coils.
[Reply]  [No Email]
pulling kid
09-04-2012 16:15:29
174.124.67.139
 Re: oliver 77 in reply to mkirsch, 09-04-2012 07:11:05
thank you for the information, im sure thats the problem... i will try that
[Reply]  [No Email]
OliverNate
09-03-2012 18:45:19
206.147.20.11
do you have new plug wires on it? if not maybe your coil wire is bad, also check over your wires for the ignition system. I got a Oliver Hart-Parr 70 that I switch to 12 volt and all I did was switch the polarity on the coil. and haven't had a problem, the coil cracked on me (left ignition on after I ran out of gas) and leaked out some of the oil and it still works just fine.
[Reply]  [No Email]
pulling kid
09-03-2012 19:08:57
174.124.67.139
 Re: oliver 77 in reply to OliverNate, 09-03-2012 18:45:19
i think the wires are in pretty good shape, my coil is also cracked but i took the coil off of our 66 and still did the same thing, how do u change the polarity on the coil
[Reply]  [No Email]
J. Schwiebert
09-03-2012 09:29:54
209.143.28.10
Yes: That is why they cut the voltage back to 6. If you are using an alternator did you change the polarity on the coil?
[Reply]  [No Email]
pulling kid
09-03-2012 14:19:33
174.124.67.139
 Re: oliver 77 in reply to J. Schwiebert, 09-03-2012 09:29:54
no, the 66 has the same setup but runs fine... how do u do that
[Reply]  [No Email]
J. Schwiebert
09-04-2012 17:44:34
209.143.28.10
 Re: oliver 77 in reply to pulling kid, 09-03-2012 14:19:33
The wire that goes from the coil to the distributor must always be hooked to the post that has the same marking as the ground on the tractor(negative ground negative post? You also need a 12 volt coil or an external resistor.
[Reply]  [No Email]
Oliverlover982
09-03-2012 07:51:24
174.253.176.186
Might also be the coil mine did that changed the coil and she runs like new again
[Reply]  [No Email]
pulling kid
09-03-2012 08:45:01
174.124.67.139
 Re: oliver 77 in reply to Oliverlover982, 09-03-2012 07:51:24
took the coil off our 66 and still did the same thing
[Reply]  [No Email]
Buster
09-03-2012 07:33:19
69.29.87.211
Have you changed the points and condenser?
[Reply]  [No Email]
pulling kid
09-03-2012 09:03:11
174.124.67.139
 Re: oliver 77 in reply to Buster, 09-03-2012 07:33:19
i picked up a tune up kit, it was the wrong points, changed the condenser cleaned up the points, seemed to have good spark, i suppose i could take the points off the 66 and try that
[Reply]  [No Email]
pulling kid
09-03-2012 09:12:20
174.124.67.139
 Re: oliver 77 in reply to pulling kid, 09-03-2012 09:03:11
could the points be bad even after we cleaned them up, gapped them0.20 rolled it over and watched them spark. would the 12 volt burn them out faster?
[Reply]  [No Email]
pulling kid
09-03-2012 18:25:41
174.124.67.139
 Re: oliver 77 in reply to pulling kid, 09-03-2012 09:12:20
i put the carberator off of the 66 onto the 77 it ran excellent for about 4 to 5 minutes, then started to miss and stutter, when i start it the amp gauge goes past 20
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
