young
need help, i have a oc-12 . engine is getting fuel in oil at a pretty fast rate. it has a flange mounted pump . i have replaced the double shaft seal in pump with no better results.the engine runs good and doesn"t smoke. i need some good advice. thank you. bud
DOES IT HAVE A CAM OPERATED LIFT PUMP, SEEN THOSE LEAK REAL FAST .DIAPHRAM CRACKS AND LEAKS IN TO THE PAN, MOST OFTHE TIME THE MOTOR RUNS GOOD TO
That is a later OC-12 as the early OC-12 used the Model A Roosa pump which is driven by a driveshaft. I will double check but I don't think you have a lift pump. Most likely your two U-cup seals on the drive shaft and maybe the tube in the injection pump need to be replaced. How can I contact you? Thanks: J.
