| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: PTO Lever and Clutch Problem
[Return to Forum]
| Author |
[Modern View]
| ollie770
08-19-2012 20:03:00
166.182.3.145
I rebuilt the PTO clutch pack with new disks on an Oliver 770. I installed the shims for new disks according to my shop manual. The lever is very easy to engage (too easy) and seems to travel further ahead than it should. You can "feel" the point where it should snap over center but the lever doesn't stay ahead on its own (goes all the way forward but doesn't stay there on its own). There is NOT a nice snap when you release the lever, but when you dis-engage it, the PTO shaft does stop turning. When disengaged, there seems to be a little noise that isn't normal in the PTO bellhousing. (Has new gear oil and is full to the check plug). I did not replace the three little springs on the pressure plate but aren't those only to help with disengaging the clutch disks? (which it disengages fine) Could this be caused by the throwout bearing and the lever forks both being really worn and having too much slop? Any other ideas and advice? |
| Tramway Guy
08-20-2012 07:47:21
67.249.37.53
Re: PTO Lever and Clutch Problem in reply to ollie770, 08-19-2012 20:03:00
| Have you checked that the pin that connects the lever to the release shaft and the key that connects the throwout fork to the shaft are not sheared? |
| ollie770
08-25-2012 12:48:23
166.182.3.5
Re: PTO Lever and Clutch Problem in reply to Tramway Guy, 08-20-2012 07:47:21
| I finally got the cover off and found the key (thick washer) on the fork to shaft was sheared in half. Put a new one in and all is well. THANKS for the idea!! |
| J. Schwiebert
08-20-2012 04:46:11
209.143.28.10
| Sounds like too many shims in the pacs. It should take about 35 pounds of effort at the end of the handle to snap the handle overcenter |
| ollie770
08-20-2012 20:31:54
166.182.3.21
Re: PTO Lever and Clutch Problem in reply to J. Schwiebert, 08-20-2012 04:46:11
| I had three less shims in place and everything was pretty much the same. According to the shop manual, it should have 18 brass shims and 4 steel ones with new clutches. Out of the 2 parts PTOs I have, I found no steel shims, so I used 22 brass shims and that should have been really close to the original thickness. The roll/tension pin the handle to shaft is good, I will have to pull the bellhousing and check for the key on the forks at the shaft. If the key is good, do I go to like 15 shims or is it fork/throwout wear? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
