Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1850 HYDRAULICS DUMPING TO THE TRANNY
[Return to Forum]
LUKE BARBIMSKI
07-27-2012 15:06:54
99.54.162.99
I was mowing hay with the 1850 and took a 15 minute break for both of us to cool off. Came back after the break to raise the cutter up to check oil levels in the mower gear boxes and the arms wouldnt raise, nor the hydraulic cylinder and steering was gone. No leakage found. Long story short it's dumping it to to the tranny and I mean fast. I have several olivers 50 series but never seen a seal or gasket go that fast ( i checked the hyd. oil level before start up and it was normal, never uses hardly any hyd. oil. After this incident I added more oil to it and the pump works as it should, arms raise, remotes work. No external leaks til it started coming out of the shifter hole. MY QUESTION.... What caused sudden loss of fluid? I'm thinking the seal on the lever for the three point but i've seen the pump seals throw oil to the tranny too but not at such a high rate. nothing is rattling so I think I have a good pump. Its works great as as long as it has oil to pump. What do ya'll think may be the problem here.
[Reply]   [No Email]
jim30
07-29-2012 08:39:17
142.68.120.139
 Re: 1850 HYDRAULICS DUMPING TO THE TRANNY in reply to LUKE BARBIMSKI, 07-27-2012 15:06:54
Hi just thought I might add that my 2-105 was doing that and the clutch pack seal was blown. I am in the process of repowering it with a 5.9 cummins this week. I have been searching the forums for part numbers on bell housings, engine mounts and fywheels.
[Reply]  [No Email]
e
07-29-2012 08:45:21
69.66.234.201
 Re: 1850 HYDRAULICS DUMPING TO THE TRANNY in reply to jim30, 07-29-2012 08:39:17
Send me a note. I can help point you in the right direction.
Eric
[Reply]  [No Email]
guss62
07-29-2012 06:43:52
75.207.193.136
I had a guy tell me that if it wasent leaking to bad you could use 303 hyd. oil in both so when they mix it wont hurt anything ???
[Reply]  [No Email]
rrlund
07-29-2012 14:57:56
207.241.137.116
 Re: 1850 HYDRAULICS DUMPING TO THE TRANNY in reply to guss62, 07-29-2012 06:43:52
Trouble is,if it's a pump seal,it doesn't just leak a little. If it's the seal on the draft control leaking a little,you're probably OK if it doesn't get too over full. I think you're going to start having trouble with seals if you let it get overfull for very long.
[Reply]  [No Email]
Don-Wi
07-28-2012 20:35:51
75.207.179.3
I changed mine because it was getting close to 500 hours anyway, but when I put it back together I had the gears standing on each other, so the new oils got mixed before I even started it.
I drained 5 gallons out of the rear, then I put some of it back in till it came out the check plug. I still have about 3 gallons of mixed oil left that I'll use on chains and things like that.
Donovan from Wisconsin
[Reply]  [No Email]
hd6gtom
07-28-2012 12:10:40
75.170.237.148
My 1800 did the same thing one minute it was fine the next all the oil was in the other housing. replaced the pump and all is well.
[Reply]  [No Email]
rrman61
07-27-2012 20:54:46
174.69.208.96
Would it be harmful to keep using the hyd/gear oil mix in the transmission that results from the pump seal going out or should I drain and replace with fresh gear oil?Had the same problem with my 1650.
[Reply]  [No Email]
rrlund
07-28-2012 06:31:48
207.241.137.116
 Re: 1850 HYDRAULICS DUMPING TO THE TRANNY in reply to rrman61, 07-27-2012 20:54:46
I sure don't want to be responsible for somebody else screwing something up,but I'll just say I didn't change mine. But then I'm tighter than a bulls azz in fly season,so if you're not comfortable with it,changing it might be a good idea.
[Reply]  [No Email]
Don-Wi
07-27-2012 20:38:21
66.87.7.204
Thats exactly what my 1600 did a few months ago. I finally changed it out last week. The seal on the pump was very obviously blown out. i will give this caution... make sure the gears mesh together.mine stood on each other the first time I put it together so I got to do it twice.
[Reply]  [No Email]
Stu
07-27-2012 18:08:15
50.102.21.142
Must be something up with the 1850s lately. My 1850D is leaking into the rear end as well. I have not had my 1850 but about a month. Mine started after puttimg the loader on. I jinxed myself by making the comment that it was the first time I bought a tractor and the trailer floor was free from oil when I got home. Seems all I do is fix leaks. Good luck with yours. Stu.
[Reply]  [No Email]
Anthony vrazel
07-27-2012 17:30:12
99.54.162.99
Thats what I figured rrlund,regardless I have to pull the unit up to inspect and repair. Oh what fun. Thanx Bud!
[Reply]  [No Email]
rrlund
07-27-2012 16:13:24
207.241.137.116
Mine did the same thing when I was planting corn. Two things can cause it. Front seal in the pump blows and lets the oil blow out through the bearing that the pump drive gear sits behind,and there's a seal around the draft control rod that comes right up through the bottom of the pan.
Mine happened to be the pump seal,and yes the pump still worked normal,I just had to keep stopping and draining the oil off the rear end and pouring it back in the hydraulic reservior to get finished up planting.
That draft control rod isn't in the smaller 50 series. It's external on the 1550 and 1650. It comes right up behind the flow divider.
When I got the pump out of mine,I could see by looking real close that the seal was blown. I replaced the one on the draft control rod too though while I had it apart.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
