Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: question on 1855 injector
[Return to Forum]
MikeO-WI
07-21-2012 21:21:37
68.113.235.62
My son noticed fuel leaking down from one of the injectors on my 1855. Since we had to pull the injector pump to replace a stud, we decided to figure out what was going on with the injector. My first thought was the rubber T was leaking or broken. Not the case. The injector was leaking fuel up from the injector body. It also was loose even though you could not tighten the bolt down any more. Upon removal (which was real easy) we found a steel washer on top of the rubber seal near the top of the injector. The tip had some carbon on it. Not sure what they did but it looks like they didn't seat the injector all the way down. Has anyone ever seen this before. Is there a way to clean out the carbon at the bottom where the injector goes in. I removed the washer and re-tightened the injector. At first it looked like it was fixed and the number 2 piston was firing again, but then it stopped and fuel was again pouring out. I have never seen this before. Any ideas?
Thanks
[Reply]   [No Email]
J. Schwiebert
07-22-2012 06:20:27
209.143.33.152
 Re: question on 1855 injector in reply to MikeO-WI, 07-21-2012 21:21:37
Did you test the injector? There is a reamer you use to clean the bore. It has a Deere OTC tool number. Always change the Teflon seal as well.
[Reply]  [No Email]
MikeO-WI
07-22-2012 16:06:51
68.113.235.62
 Re: question on 1855 injector in reply to J. Schwiebert, 07-22-2012 06:20:27
we are taking it in on Monday to get tested. Seals will also be replaced if it is good. I will let my hired man know about the JD tool if the diesel shop does not have it.
thanks
Also can you send me the timing specs you mentioned before. If you could send it for both versions, I can figure it out.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
