| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: I believe a Oliver super 55 diesel.
[Return to Forum]
| Author |
[Modern View]
| Jason Yeager
06-09-2012 18:10:51
96.253.213.91
I purchased a Oliver tractor with henry loader and backhoe. This tractor does not run right this second and to be honest I have not tried starting it yet. The person I bought it from got it from a friend of his and decided to part with it. The gentleman told me it was a diesel. I am sort of questioning that. From looking at the tractor the right side looks to be what is a glow plug or some sort of wire threaded into block. I would say towards the rear mid to top section. The battery in the machine is very large looks like more for a diesel tractor than a gas. so those are why I suspect it was a diesel. This machine has no injection pump, it has a updraft carburator on right side of block. I have the information from the SN# tag it says its a Specifications Number 15-0116 and serial numberf 37 502 - 518 The starter sn# is 5H18 the model #1107147 Delco Remy. I want to make sure I get and know all the info needed before trying to fire this beast up. It's actually in great condition minus the bellhousing where front axle arms come back to looks like sway bars or somthing BAD DESIGN, Bell's cracked bad both sides. Any help would be great as I saved this girl from the scrap yard. Thankyou ! |
| Jason Yeager
06-12-2012 06:15:32
166.248.36.138
Re: I believe a Oliver super 55 diesel. in reply to b a star, 06-09-2012 18:10:51
| Quoting Removed, click Modern View to see
How bad of a job was it. I am assuming the tractor has to be split, might as well do a clutch and seal while in there. I need to find some info on Henry loaders also. I want to pull the plugs and make sure motors free , then off comes the loader. |
| Jason Yeager
06-11-2012 11:23:21
166.248.32.213
Re: I believe a Oliver super 55 diesel. in reply to Jason Yeager, 06-09-2012 18:10:51
| Thanks for the help. I had a 45 deere that used to start off gas and switch to fuel it was carbureator, this is my first Oliver so was not sure how the old ones worked. Figures it would have a injection pump and glow plugs instead of spark plugs but was not positive. This machine I got the guy I got it from knew nothing about tractors so he was going to scrap it. Needless to say I got it for a 1000.00 so now to get a charge on the battery pull the plugs, clean carb, check oil and try to turn it over. I think it is not to long ago they stopped running it the cylinders for the hydraulic arms a spotless no surface rust at all. Any advice on dealing with a machine that you are unsure runs would be great. |
| mkirsch
06-11-2012 06:03:59
64.80.110.75
| Carburetor = gas
Your "glow plug" is actually the probe for the water temperature gauge. It is screwed into the water jacket in the head. |
| Super 55
06-09-2012 23:11:36
70.69.44.167
| Well if it has a carb, it is not a diesel. That housing that is cracked can be welded or you could check with Kent Gordon, (he keeps an eye on the page) to see if he has a good one. The serial number makes it a 1956. On that piece that is cracked, see if the casting number has an A as a suffix. They beefed it up. The A is the later part number. It's going to be 1E-599, 1E-599-A, or 1EA-599-A frame center. |
| Jason Yeager
06-11-2012 21:16:50
96.253.213.91
Re: I believe a Oliver super 55 diesel. in reply to Super 55, 06-09-2012 23:11:36
| I checked it, it is indeed a IE-599 no A |
| Super 55
06-11-2012 21:47:02
70.69.44.167
Re: I believe a Oliver super 55 diesel. in reply to Jason Yeager, 06-11-2012 21:16:50
| My original piece was cracked and welded by a previous owner. I happened to find a replacement with the A suffix. Kent parts out lots of Super 55s.I have gotten parts from him in the past. |
| Farmritch
06-09-2012 18:41:39
50.129.50.231
| sounds like pictures are in order |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
