Anonymous-0
The 105 White does not shift into 1,2,3,5 or the left side of the shift pattern. The other gears work fine. What is wrong and what type of procedure is required to correct the problem? The gears 1,2 3,5 will go into gear, but not all the way and then it pops out. It does not grind or have any sound while using the other side of the transmission.
I would bet you have a shift fork issue. It may be bent or came loose. I'd pull the top off the transmission and take a look at it.
