354 perkins injectors/injection pump
Anonymous-0
I have an oliver 1850 diesel with the 354 perkins non-turbo. I pull competively in the non-turbo classes locally but I'm looking for more power without a turbo. I have already maxed the pump and believe that the injectors are bad. I know MF used the 354 perkins in many of their tractors and combines. Does anyone know or have an opinion of what combine/tractor I need to get the injectors/pump from? thanks
have your injectors lazered out to four hole .024. Get a 11mm head for your pump. the combine pumps have a different drive.
I know of some guys that can work on your pump if it needs it and I know a guy that will work on and lazer injectors cheap. If interested send me an email.
How many rpms are you turning? Is timing advanced?
Engine could be bored/stroked. Head/cam work can be done
