Marty from MN
Hello, I'm posting for my BIL. He has a 1550 with a loader on it (not sure of the brand), but it has down pressure. The hydraulics are causing the loader to bounce on when going down, but not on the way up.
We also hooked it up to a haybine with a 2 way cylinder and it raised it smoothly, but bounced wildly on the way down. We switched the hoses so the valve was working the other way and had the same result. Smooth on when lifting, bouncing when going down.
The haybine works perfect on my 560, so we know it is in the Oliver somewhere.
Any ideas for things to check? I thought there may be a plugged screen somewhere in the hydraulic block, but I don't know much about Olivers.
Thanks in advance.
Thanks in advance.
