We finally got our Oliver 1800 put back together. We had a problem with overheating then had rain water in two cylinders so we tore the engin apart and did the following: New Radiator, rebuilt injection pump, rebuilt injectors, new wristpins, new rod cap bolts, new pins, two new sleeves/pistons, cleaned fuel tank, rebuilt the head, installed new cluthc and fiber disk, replaced the PTO damper, and installed new batteries.
I had the tractor started for about 2 minutes last week, but had to turn it off. When it was running I found that two banjo fittings and the bottom plug of the injection pump were leaking plus fuel was seeping out of one of the injectors at the block. Now I can not get it started again. Any suggestions? I bled the lines and fule seems to be pumping well when the lines are cracked.
Jim
Jim
