550 transmission fluid check
back of the tractor to the right of the pto shat there is a square plug. you fill the trans/rear end until it comes out that hole. i believe the book for a 550 calls for 30wt engine oil. some use 80/90 wt without a problem. if you drain the trans make sure you pull all three drain plugs i believe they take a 1/2 drive.
