I"ve got a JD 2150 that came with a set of Oliver wheel weights on it. They"re the small kind, with the look of a slightly tapered cone - I"d bet they weigh around 100 lbs each. They have 4 bolt holes in them and appear to say 1E1235 on the casting.
I have an opportunity to buy more of these weights, but I want to know how they"re supposed to be stacked. Do you only fix the inner weight to the wheel with 2 opposing bolts, and then use the other 2 holes to hold the next weight on, and so on?
Or do you use 4 lengths of all-thread with a nut on top of each weight? Looks like there might be room to do this, but I"m not sure.
