pto clutch repair on 550 oliver tractor
Please be advised that there are two set screws holding the pack in place! It will save you a lot of time that I lost.
Thanks. Did u have to split the tractor apart or can u replace them through the hole in the bottom of housing.
Its not too bad of a job. You do have to do a Z split like J suggested. A manual is helpful for the first time you do it. Its pretty clear once you get into it.
The hole in the bottom is for adjusting the clutch only. You can't get in there and get parts out through that little hole.
