A little toungue in cheek subject :wink: Awhile back I posted a question about how a 550 would handle a JD 1209 haybine. Well my buddy let me use his 520 JD for the haybine so I could leave the Ollie on the baler and not have to switch back and forth. Fast forward to last evening. Get home from work and JD won't start, dead batteries. Take the 550 with a chain and drag the JD off the haybine, hook the Ollie up to it and cut 6 acres of the thickest hay I have ever cut. Worked her hard but she did a good job. Thought you other Oliver guys would like to hear how the right color green had to be used to get the work done.
