2-105 Transmission leak
14hunter
New User
I have a 2-105 that is leaking gear oil from around the lift arm anchor points on the transmissing case. Does anyone knok what needs to be done to fix this?
Thanks,
Dace
Does you tractor have a Cat ll 3 point hitch? Needless to say the oil must be drained and the PTO unit remove to start with A parts book and manual would also help.
It's a Cat 2 hitch. It looks like the leak is from the oil seals on the draft control support shafts. I have an IT service book. The tractor is a 1977 model so hopefull it's just old seals and once replaced; the leak will stop.
Thanks
