Anonymous-0
I have a 1967 oliver 1850 diesel with a spun crankshaft main bearing that ruined the crankshaft and engines cylinder block.(354U84930) I have found a local farmer with a low hour (1863hrs)1977 massey ferguson 510 combine that has a 354 perkins engine serial number 354UA65159L in it.The intake and exhaust manifold bolts appear to be the same arrangement and sequence. It does have the tin cover for the valve tappets and pushrods on the side. I have read on ytmag here that I will need to reuse my original oil pan, unplug oil galley to change oil filter sides and reuse my front timing cover with water pump.
My main concerns are if this engines serial has an "L" for lip type rear main seal.Will this style crankshaft have any issues with the original 1850 flywheel and flywheel housing that used rope crankshaft seals?
Can I just swap the injector pump auxillary drive shaft with the worm gear on it between the two engines so I have the original tachometer setup?
And the last question regards injector pump.It is set to idle at 550 rpm and high no load of 2090 rpm. To adjust the high idle is all I need to do is loosen up the throttle stop on the outside of injector pump.Or are there weights and springs inside the injector pump that will need to be changed?
Thank you all in advance for the help and if there is anything else I need to look at before buying this engine please let me know...
