on our 1755 the throtle lever has been stiff and almost to the point I wanted to oil it up and then it started floping and the tractor
ideld down and I shut it off got to looking the rod that goes past the back of the carborator was rubing on the belhousing enogh to couse the stifness and the pin fell out back there where it conects to the rod that goes up to the lever I bent the rod and now if you are running less than 1800 RPMs when you downshift the over/under it will bring the tractor to an Idel and some times stall I think I need to titen up the lever can this be dun without taking the dash apart how do I get to the clutch that needs titend up if that is it.
Thanks Thomas
Thanks Thomas
