88 pto shaft
chucksoliver77
did you have the pto housing off ththe trans case? if you did you must install the pto housing loose then slide in the pto shaft to align the hole inthe pto housing with the hole in the trans case, then tighten the pto housing to the trans case .
Hey chucksoliver. Were you responding to my
question? If so thanks. I was thinking the same
thing after staring at the tractor for a while. I
will give that a try after Xmas and let you know.
Thanks again. Merry Xmas
