Anonymous-0
I want to change out the coil and distributor with an electronic ignition device. Does anyone know the problems I might incur doing this?
I am not getting any spark in the points, so either the coil or points are failing. Either way, I would like to try the electronic ignition if it will work and would not be too difficult to install.
Thanks,
David
Thanks,
David
