77 Cast Rear wheels
1755
Our Club has a RC 77 with Cast centers on the back and it is going to get new to it rears we were abel to get the bolts and the clips off that keep the steel wheel on the Center but the bolts were rusted and had to drive half out with the hammer and torch out the rest is there going to be a problem using regular bolts insted of the square ones besides they will have to have a wrench on them when we titen them up can you even get the square head ones any more
There won't be a problem putting new hex bolts in. I would use hardened bolts tho. Just be alittle patient when you put them on, as you may or may not have to use a back wrench.
Yes, square headed bolts can bought from bolt suppliers. Got some here from Royal Hose an Brass supple Co.
MEagain, 1/2 by 31/2 grade 8 with heavy nut was 1.98 per bolt and nut. The Co. was out of Madisonville Ky. Got them for my 1650, wheel started creeking old soft bolts had loosen from carrying whieght on three point or thats what I thought could have happened plus rusting away.
that is what I wanted to know I did not think about hardness I will have to see what the diferance in the prise is and go from there thanks Thomas
