My 570 Wide front Diesel with 18.4 x 34 rears weighs approximately 7500# with no fluid or weights and dynos at 80 HP on a stock engine. Can't help you on the WD9.
The WD9 will gross probably over 10,000 if weighted and fluid in tires. Only 50 horse or so. Don't know about the Ollie.
The WD-9 made 46 HP on the belt at Nebraska. The Cockshutt 570 was RATED at 61 PTO HP, according to external_link...
35 had new engine when I bought it.Upgraded version of a 198. 4 in. bore instead of 3 3/4.,bigger crank journals etc. and electronic ignition. Came new from hercules factory.That is about all I know.
