Moline_guy
We lost drive on the live shaft on the 4-150 the other day, i am guessing it stripped out up front somewhere. Is their only the one live shaft from the flywheel to the rear of the transmission where the drive shaft hooks too or is there two shafts? Years ago we had to replace a shift coupler in it and we split the tractor ahead of the pivot point and removed the live shaft from the rear to work on the the shift coupler. Seems to me someone said that there is a short shaft from the engine through the over under and then this long shaft to the rear of the transmission. If there are two shafts is there anyway to tell which shaft stripped? If its the front one we will have to pull the engine, if its the rear one i would guess we have to split it ahead of the pivot point again. The top drive shaft can be turned by hand when the engine is off and does not turn when the tractor is running. Thanks for any advice on this.
