Merlin in Rushford
Hello! My employer owns a 1979 model White 2-155 (small three-speed). It runs good, has good power, reasonable exhaust smoke, and limited blow-by and oil consumption. The engine was rebuilt 15 years ago. Yesterday, I did a compression test on each cylinder. The "dry" readings were 340 PSI (lowest) to 400 PSI (highest), averaging 360 PSI. The "wet" results (with oil injected) were 50-60 PSI higher. It starts hard when cold, but will re-start readily when warm, and runs smoothly. It has seen it's share of ether. The I&T Manual calls for 300-350 PSI of compression, which seems low to me. What range should I have? Do I possibly have injection timing, valve timing, or injector pressure issues? Any replies would be helpful. (I know, I know...put in a 6CTA Cummins!) Can't afford that at this time. Thank you!
Merlin
Merlin
