Well I finally had the time to replace the broken hydraulic line that broke while plowing last fall. I use the AGCO upgrade of a hose and line and refilled the resevoir so I thought I was good to go. Well.........
When I fired up the tractor to test the steering I had NO STEERING. I turned the wheel completely in each direction several times but still no response. The only movement was at the very end of the steering cycle when you 'hit' the max, but that was not actually moving the wheel.
I have the sheet metal off already since I have to replace the valve cover gasket and am preparing to get to the steering cylinder. Might I have 'stripped' the gears in the cylinder last fall? What am I looking at to rebuild/replace this cylinder?
I have the Saginaw steering motor and cylinder.
Jim
Jim
