3 point kit for a Cockshutt 30, and a couple other questions
30_Eric
Hi guys,
New around here! I have a 52 Cockshutt 30 that doesn't have a 3-point hitch. Are there kits available to convert it into a 3 point? I tried searching the web a bit, but came up with garden tractor stuff and some for the back of a car!
Also, what's the easiest/least expensive way to get replacement hydraulic hoses? Are there any parts suppliers out there for Cockshutts to match the hoses, or are the fittings generally the same and a generic hydraulic hose would work?
Along those same lines, how about replacement radiator hoses?
Thanks for any help.
Eric
Thanks for the info guys. Any thoughts on where to get replacement parts like the hose for hydraulics and radiators, and how about tune up parts as well like points, dist cap, rotor, maybe a new coil?
Thanks again,
Eric
Agco has a tune up kit for your 30. part # 79024748v includes points, condenser and rotor. Also a plug wire set # 79024410v. And 6 volt coil #79024737v.
Hi, actually I am working now at putting togeather a couple complete 3point units for 30 and 20. I can provide you with replace radiator hose numbers. as for hydraulics just go to NAPA or a hydraulic shop and they can make what ever you need. email me about other stuff.
