I was raking hay last saterday with the 58 880 NF and hit a ditch and snaped the front end spindel off right abuv the bearing I thought I blew a seal in the power stering becous it turned and would not turn back but I backed it up and could tell it was broke I was wandering if any one was makeing new ones I get off work at 5:30 so I have not got to any of the lockel plases to look or ask acording to the Agco parts book on the computor there was only one for the 770 and 880 with power stering
Also I had to open up the power stering on the front to get to the bolt that holds the spindal in this had been don befor I could tell and there was a plug in there on top the bolt it was smooth side up and it was a pain to get out it looked like it had a pry ing place on the other side is it supost to be up will I have to bleed the system befoe I am done I am not shur exacly witch setup I have but this tractor has a generator with the power stering pump shaft cut off and a whole sawed threw the hood for the dipstick and a pump up there and it dous not have a stering shaft going down to the stering gear
Thanks Thomas
Thanks Thomas
